Bolt ID 1999 B5 can you help?
Old Feb 4, 2016 | 05:35 PM
Orion1337's Avatar
Default Bolt ID 1999 B5 can you help?
http://imgur.com/0G27JOR
Here's an image of the locking side of the bolt. The link isn't wanting to embed right.
I was doing my tie rod ends on my second b5 that I just bought, it has a minor gender bender and bend the rod end. Anyways to the point, I was putting it all back together and over torqued the "Tie rod end pinch bolt" as people have called it on the forums, but after the last 4 hours of searching I can't find anything in terms of buying a replacement.
It's the cross bolt that hooks the tie rod end to the control arm.
Old Feb 4, 2016 | 05:52 PM
elduderino200's Avatar
Is it one of these?
https://www.ecstuning.com/Audi-B5_A4...Arm/ES2708162/
Different shape but this is the tie rod end hardware.
If you go to ecs and look under suspension, it'll have more options.
Old Feb 4, 2016 | 05:58 PM
Orion1337's Avatar
Originally Posted by elduderino200
Is it one of these?
Ecs doesn't have it as far as I can tell. It's long and it's one of The two bolts that make contact with the tie rod end.
Old Feb 4, 2016 | 06:24 PM
Old Feb 4, 2016 | 06:28 PM
Orion1337's Avatar
That's the one
Old Feb 4, 2016 | 06:31 PM
Orion1337's Avatar
Sweet thanks man, I've seen it called 40 different things today so it was near impossible to find any sort of part number.
fowvaydriver
Sep 28, 2011 12:50 AM
whitey
May 5, 2010 10:54 AM
banderson121
Mar 14, 2007 02:45 PM
