boom
Old Jan 6, 2009 | 05:42 PM
TeeterTawter's Avatar
well, the turbo was not starved for coolant, the turbo inlet pipe fell off.
the egine block is not the housing for the T-stat or waterpump, maybe for your 01 but not my 00 atw. heres a t-stat housing http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
and search ECS for a waterpump with housing
Old Jan 6, 2009 | 06:55 PM
AudiTurbo's Avatar
good luck!
Old Jan 6, 2009 | 07:16 PM
somebody5788's Avatar
Originally Posted by cincyTT
Your car most likely wouldnt start if the TB skipped due to the low compression from the valves bending, not to mention major loss in power. If you car isnt overheating when sitting awhile after the car has reached temps, its most likely not the waterpump either. I would check the turbo for shaft play or damaged wheels after seeing if the car overheats.
I've seen plenty of cars run w/ after jumping a tooth or 2 on the TB. They run like **** but they run.
Old Jan 7, 2009 | 04:56 PM
Tweaked's Avatar
My bad. For some reason I thought you had an AWM.
Old Jan 7, 2009 | 10:44 PM
onepoint8tee's Avatar
Sounds like misfires to me. ATW coil packs never die and there is no ICM. So it's more than likely the maf or the plugs. I had a hairline crack in one of my plugs a while back in the porceline insulator part. It caused misfires only under heavy load. Start with replacing your plugs. Misfires can easily go unregistered if they are very random and seldom. You never had a cel? I had waterpump give the same sounds a while back. There was play in the bearing and the impellar is clanking around. Took a while to pinpoint.
Old Jan 7, 2009 | 11:11 PM
I have replaced all sparkplugs, replaced T-stat with housing, and replaced the entire waterpump. so far no sounds and no more backfires. its only been 1 week. but sounds great. and no, I never got a cel or any codes.
Old Jan 8, 2009 | 05:03 PM
Tweaked's Avatar
That's that service advisor talk again...
2wdBlazer
B7 Models
11
Mar 10, 2011 12:50 AM
usernamehere
Jan 4, 2011 03:34 AM
OOOO-hBoy
Apr 28, 2009 05:35 PM
pullacowonaski
Apr 12, 2009 08:18 PM
