boost gauge
Old 09-28-2009, 02:49 AM
B5Bobby's Avatar
Default boost gauge
do the make the steering column "podi" boost gauge mount for the B5 a4? if so where can i get one, if not should i just go with the vent mount? and anyone selling or know where i can buy a decent in-expensive boost gauge. i was lookin at VDO and saw a couple on ebay. just thought id try on here.
im located in Covina CA, if anyone knows of some shops in the area
Old 09-28-2009, 10:18 AM
codymack43's Avatar
I was looking at the Podi but I decided I want a 3 gauge pod to go on the left side rather than over the steering wheel.
Old 09-28-2009, 10:29 AM
Mike-2ptzero's Avatar
If you need a boost gauge I have 2 used Autometer gauges(phantom and ultra-lite).
Yes Podi has a steering column setup for the B5 A4 and I am a Podi dealer if you want one. I can also get you the NewSouth Performance ColumnPod, that one puts the gauge in the center.
Old 09-28-2009, 11:24 AM
AudiTurbo's Avatar
I have the steering column boost gauge and love it. I got mine from newsouthperformance because podi didn't make it for b5 at the time.
Old 09-28-2009, 12:00 PM
MrPibb's Avatar
I made my own vent mount for my boost gauge, it's cheap, easy, and looks pretty bad *** if you do it right. As far as the gauge goes the first thing i'd decide if i were you is do you want an electronic or mechanical one, mechanical is cheaper, but electronic are more accurate.
Old 10-23-2009, 10:09 PM
bbboy's Avatar
Member
Default Installed my VEI gauge
I just got my VEI gauge from Podi.ca, I didn't want to cut anything, so I bought
2" ABS pipe cap, drilled holes on the back of it.
In order for the gauge to sit in the cap, I had to turn it down a bit.
Connected it to the fuel pump wire, ran a vacuum hose...trick is - the vacuum hose should run almost straight from the back of the gauge, then I put 4-5 layers of self-adhesive (double side) tape so that the cap just sticks to my dash. No drilling or any mods on the dash, anywhere.
Old 10-24-2009, 09:29 AM
CCA4's Avatar
bbboy, how come you decided to put it where you did? seems like it would be hard to see while driving. looks like a clean install though, well done.
Old 10-24-2009, 09:50 AM
bradtyler02's Avatar
Yeah, that does look like a clean install. Nice DIY.
Old 10-24-2009, 09:52 AM
Mike, do you have any links to pics of those two different pods? I'm going to need a boost gauge, and will probably order one with my phantom purchases while in Iraq (as in, not telling the wife I ordered it, just tell her to put it with the car and I'll install it when I get back).
Old 10-24-2009, 05:24 PM
kayakman13's Avatar
Cool
I did the vent mount pod, but since I'm cheap I used a dremel on my baby.
(How can people justfiy $2-300 on a boost gauge/pod!?) It took a few hours of dremeling and filing to get the fit perfect, but I'm really happy with it. All in all I'd say it was a 3.5/10 for difficulty because of the need for tools, the possibility of really ******* up your vent, and the time.
Drivers View: I'm holding it up with my fingers. It sits just a few degrees lower normally. I'm waiting to get an ultrabright LED (because the normal one is too dim) before I glue it in place.
From outside: Most people dont even notice it.
At Night: (Its a dimmer red than stock)
Quick Reply: boost gauge
