boost gauge problems
Old Jan 24, 2009 | 01:24 PM
singleturboaudi's Avatar
Default boost gauge problems
its a stock 1997 a4 1.8t. got an autometer boost gauge. installed said gauge accordingly. put the t-fitting in the correct place. did everything properly, lets just put it like that. and ive checked multiple postings to make sure it was done correctly. and when the car is at idle it does read -20 vaccum. stock boost is 7 lbs, so on the roll it should boost up to 7 but it doesnt. the needle doesnt go past 0 and the car doesnt feel any different. so pretty much its reading the vaccum but when your driving it doesnt read the boost. somebody, anybody, help?
Old Jan 24, 2009 | 01:34 PM
AudiTurbo's Avatar
Check and see if your wastegate is broken (With the car off and cool see if you can move it back and forth which you should be able to) Is it manual or auto! More info please
Old Jan 24, 2009 | 02:18 PM
its a manual. ill do that before i drive it. what other info do you want?
Old Jan 24, 2009 | 02:53 PM
AudiTurbo's Avatar
That is what was wrong with mine
Old Jan 24, 2009 | 07:28 PM
Jc61990's Avatar
where did u tap into for the t-fitting?
Old Jan 25, 2009 | 07:32 PM
which way should the wastegate be able to move? like front to back, side to side? i put the t-fitting where its supposed to be, on the hose that goes into front of the manifold. i checked alot of write ups and whatnot before i did it. it should be working properly
Old Jan 25, 2009 | 10:07 PM
Jc61990's Avatar
theres 2 spots you can do that or from the manifold and FPR. thats where i put mine.. looks cleaner.
those are the possible spots to tap into. if you tapped into the one on the right then check to make sure the other end is connected to the DV
Old Jan 25, 2009 | 10:12 PM
nova_ss672001's Avatar
yea cuz on my car, the line on the right goes around and connects back to the mani or something...
there isd another line right under it though that does connect to the dv,
mine is an 01 though?
Old Jan 25, 2009 | 11:12 PM
AudiTurbo's Avatar
With the car off you shouldn't be able to move the wastegate
Old Jan 25, 2009 | 11:49 PM
slopoke's Avatar
Before you said you SHOULD be able to move the wastegate, now you said you SHOULDNT be able, my car is doing the same and i had a CEL for an N75 so i thought was my problem, but this could be it...
