boost gauges
Old Apr 27, 2010 | 01:41 AM
whtturboa4's Avatar
Default boost gauges
hey guys just joined and glad i did!! i was hopping you guys could help me find a place for a boost gauge in my 2001 A4 1.8T Quattro. pistures would be really helpfull. thanks
Old Apr 27, 2010 | 02:18 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
I'll be going with an AWE gauge mounted in the center vent.
Old Apr 27, 2010 | 10:50 AM
flynnr's Avatar
i would very highly recommend the VDO gauge... it is the same brand as your gauge cluster, and by far looks the most stock out of any gauge out there. it is simple, yet gets the job done. its only like $33 too!
http://store.42draftdesigns.com/VDO-...auge_p_67.html
there are some other boost gauges at this site as well, check them out!
http://www.42draftdesigns.com/products.html
Old Apr 27, 2010 | 10:56 AM
flynnr's Avatar
Old Apr 27, 2010 | 02:59 PM
McGovs2.7TB5's Avatar
+1 on VDO. ECS tuning is running a sale on them packaged with an APR vent pod for like $120
Old Apr 27, 2010 | 05:31 PM
audiejohn's Avatar
Member
I like my podi, it's mounted just rear of the wheel and doesn't obstruct most of the gauges in the instrument panel. + it matches the color and the type of font.
http://podi.ca/
I got the VEI System package red
Old Apr 27, 2010 | 06:09 PM
CCA4's Avatar
One spot I'd suggest you AVOID is the A pillar. The 2001 has side curtain airbags there, and a pillar-mounted gauge pod would f*ck your sh*t up if you got hit and that airbag deployed. The suggestions above are quality. Other places I've seen boost gauges pulled off nicely are the heating/AC vent to the left of the steering wheel, in a pod on top of the steering column, or any of the three center heating/AC vents.
Old Apr 27, 2010 | 06:34 PM
aledelic42's Avatar
I like my glowshift gauge (~$40 from ebay) with the steering wheel column pod from ecs (~$30)
Old Apr 27, 2010 | 07:01 PM
mikekey's Avatar
2nd for AWE Vent gauge if you have white numbers. http://www.awe-tuning.com/pages/shar...CenterGaugePod
Old Apr 27, 2010 | 07:09 PM
aledelic42's Avatar
the glowshift gauge can change colors with the button in front, including white. the needle stays red
