Boost leak
Old May 23, 2012 | 12:44 PM
Brochacho's Avatar
Default Boost leak
So I did the tennis ball boost/vacuum leak test, and can hear a leak loud and clear. But for the life of me, I can't pin point the actual leak. Any suggestions on a bitter way to pin point the leak? It is coming from somewhere either under the headers, or just behind the headers. Any help is greatly appreciated!
Old May 23, 2012 | 12:48 PM
FASTER's Avatar
Tech Slut
thats the wastegate area... are you getting barely any boost? The wg flapper is a very common issue. The best way imo is to smoke it.
Old May 23, 2012 | 12:49 PM
Brochacho's Avatar
Can I some how smoke it myself, or have it done professionally?
As far as the boost, it builds up and ten just kinda fades.
Old May 23, 2012 | 12:56 PM
Brochacho's Avatar
From what I read... when the waste gate flap craps out, it cause the car to make a loud noise when driving. My car sounds normal, just a loss of boost. It still holds alittle boost, just not the full amount it should.
Old May 23, 2012 | 07:36 PM
CCA4's Avatar
Like I said in your other thread, if you don't have access to a smoke machine, try soapy water from a spray bottle. It sounds archaic but if you can use a boost leak tester and some compressed air it works really well.
to4xxx
Jun 8, 2012 11:56 AM
onepoint8tee
Jun 27, 2007 04:38 PM
truckjunky87
Feb 8, 2007 12:33 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
a4bsix
Jul 6, 2006 04:28 PM
