boost problem
Old Sep 30, 2010 | 08:23 PM
audiphill2001's Avatar
Default boost problem
i have an a4 1.8t and just recently started running 5psi. I immediately checked the vacuum line from my boost gauge and found no leaks any suggestions?
Old Sep 30, 2010 | 09:17 PM
chocalotstarfish's Avatar
Super Moderator
Do a boost leak test... probably popped a line or check valve.
If you don't know how to do a boost leak test go to the diy here at AF and look at the one I made for it...
Old Sep 30, 2010 | 10:15 PM
okay thanks I will be sure to check it out.
Old Sep 30, 2010 | 10:19 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Did you do any modifications to the car prior to the boost decrease?
What chip were you running?
Old Sep 30, 2010 | 10:36 PM
No chip. All stock besides a cone air filter. Well i had the check engine light on because of a bad mass air flow sensor which caused my boost to decrease to 5psi. After I put a new one in, I plugged my friends computer into the dash and no codes came up so the check engine light is gone but it's still running 5psi.
Old Sep 30, 2010 | 11:03 PM
What psi were you seeing before? 5-7psi is normal for a stock ECU.
Old Sep 30, 2010 | 11:20 PM
So 5-7psi is normal for a stock turbo? Someone told me its suppose to be 10psi.......
Old Oct 1, 2010 | 03:42 AM
joenelson7687's Avatar
what year?
Old Oct 1, 2010 | 03:49 PM
Old Oct 1, 2010 | 05:55 PM
Searching for a4 1.8t stock boost led me to this thread: https://www.audiforums.com/forum/nitrous-super-chargers-turbos-26/02-a4-1-8t-how-much-boost-54558/.
You still haven't answered how much boost you were seeing before.
