boost problem
Old Oct 4, 2010 | 01:49 AM
  #21
Mike-2ptzero's Avatar
Originally Posted by lm0812
Can limp mode be confirmed with a scan or vagcom?
After installing a carbonio intake and 007 DV, I went from 15psi to 5psi. I did a boost leak test and only found one small leak by my intercooler.
Any ideas?
You might be able to on block 115 which shows requested boost and acutal boost.
Old Oct 4, 2010 | 01:51 AM
  #22
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Thanks Mike, I'll look into it.
Old Oct 14, 2010 | 02:20 PM
  #23
audiphill2001's Avatar
Welll guys i found the problem.... It was a dirty diverter valve
Old Oct 14, 2010 | 07:40 PM
  #24
Care to elaborate? What was the problem with the DV that could cause such a drop in PSI?
Old Oct 14, 2010 | 11:43 PM
  #25
yeah well i came home from school and i wanted to check the dv just out of curiosity. so i jacked the car up took out the dv and looked it through and it wasnt really that dirty but i just cleaned it a little by spraying wd-40 and i put it back in and i started the car and went around the block and i was shocked to see that it ran 10psi... i was thinking maybe all the boost wasnt really going through the dv instead it went back to the intake because after that my intake got quieter.
Old Oct 14, 2010 | 11:50 PM
  #26
Hm, well. That means its time to put my old DV back in and see if it fixes my problem.
I'll report back after the weekend.
Old Oct 14, 2010 | 11:52 PM
  #27
okay man
audia4boy24
Jul 26, 2008 11:03 PM
dgirlsdemsugar
Jul 21, 2007 09:28 PM
eurotech
Apr 5, 2006 02:18 AM
Dieselboywu
Jul 24, 2005 02:11 PM
active1331
May 23, 2005 09:15 PM
