boost problems
Old Apr 30, 2014 | 12:01 PM
CruzGa1993's Avatar
Default boost problems
01a4 1.8t when I start to go sometimes only sometimes will I get full boost and rip thru 1-3 gear but the rest of the time half or less got motor rebuilt replaced all gaskets and hoses and vac lines. I didn't remember to get a boost gauge and ran out of money. But there is a noise that's got me baffled when I push on gas turbo spools u can hear the psshh when changing gears but it almost always it psssh's (DV) when I ride a gear and don't want to change gears or it pssh's right before I change gears too. Is the DV bad or is it my N75 or both please gimme y'alls opinion. Thanks
P.s bout forgot when I'm riding and I gas it to high rpm's it will psshh and like thump or pop sound?
Old Apr 30, 2014 | 12:26 PM
redline380's Avatar
Legal Moderator
sounds like a shot DV to me for sure. either that or a decent sized boost leak. I'd say the odds of it being one of those problems is about 99%
Old Apr 30, 2014 | 12:46 PM
CruzGa1993's Avatar
That's what I was think in just wanted to hear it from someone else i don't thinks its a leak cause I spayed like a whole can of brake and parts cleaner all over the engine where there a any hoses and vac line but no change in idle thanks if not DV any ideas?
Old Apr 30, 2014 | 02:10 PM
redline380's Avatar
Legal Moderator
spraying brake cleaner cut it. There may be no leak under vacuum, but boost could separate the hoses. you will need to do a boost leak test if you dv checks out ok.
Old Apr 30, 2014 | 04:00 PM
CruzGa1993's Avatar
OK thanks ill get back to you
funon4wheels
Nov 26, 2014 03:12 PM
KG_Gabriel
Jul 14, 2010 10:47 AM
thatA4guy
Apr 12, 2010 03:29 PM
brimhall99
Nov 3, 2008 10:41 PM
acollicott
Apr 5, 2008 06:16 PM
