Boost Question??
Old Aug 24, 2008 | 08:02 PM
ceelos's Avatar
Member
Default Boost Question??
I had taken some logs today and was wondering if someone can tell me if i'M reading this right. It looks like I am boosting 30PSI (2010mbar) at some of the points when I get on it. My boost gauge reads 17-18PSI steady. Can someone check the logs that I attached and tell me if I'm right or wrong. My car is a 2001 A4 QTM with APR Stg III. Thanks in advance.
Old Aug 24, 2008 | 08:05 PM
ceelos's Avatar
Member
how do you post an attachment??? Things are different I see.
Old Aug 24, 2008 | 08:13 PM
Jc61990's Avatar
probly be easier to add a link, use like uploadingit.com and get a link from that
Old Aug 24, 2008 | 08:29 PM
ceelos's Avatar
Member
LOG-01-119F.xls
Old Aug 24, 2008 | 09:02 PM
onepoint8tee's Avatar
You have to take into consideration what the ambient pressure is where you live/what altitude. Sea level is something like 14 psi, so youd subtract that from the reading.
Old Aug 25, 2008 | 10:56 AM
Mike-2ptzero's Avatar
Atmosphere pressure needs to be removed from the log readings that the map sensor shows. So this means removing about 800-1013mbar from the readings, you can find that number you want to subtract by looking at what it reads during idle, that number is always going to change with the conditions because the DA(altitude pressure) changes.
oooos4
Sep 6, 2014 11:28 PM
TTsteve
Oct 12, 2007 04:30 PM
TurboToughTT
Jul 28, 2007 10:49 PM
JohnnyBravoA4
Jan 2, 2007 05:02 PM
02tq
May 25, 2006 02:21 PM
