boost range??
Old Apr 15, 2010 | 08:55 PM
turbo kraut's Avatar
Tech Guru
ok, one main reason to have a boost guage... it can tell you if the car is having issues without a code poping
you might be in limp mode with only a soft cel... you might have a vac leak and no cell either
you could put it in your glove box if you don't want to see it... but having a boosted car with no guage is like having sex with a condom but no end.....
i personally wouldn't do it
also "watching" vagcom while driving is not very safe at all
Old Apr 15, 2010 | 11:05 PM
hauptjr's Avatar
You made several good points. Particularly this last about watching vagcom while driving.
Let me assure you that I don't watch vagcom while driving. I log vagcom while driving and then pull the log into excel and examine the results later when I'm not driving.
This brings up a good point! Vagcom (vcds-lite) is only sampling every 1.3 seconds - which is not enough while boosting. (the more recent versions that come with a geniune ross-tech cable have a turbo mode and can sample much more frequently).
Also, vagcom has a utility/program called vagscope that I have not yet played with - but it is suppose to graph data in realtime. I don't know if it samples any faster than logging does or not. Maybe it does a better job of capturing the peaks and valleys?).
So much to learn . . .
=0000=
Aug 1, 2009 09:39 PM
Smecker
Dec 5, 2007 05:39 PM
Mikesnewaudi7447
Apr 8, 2007 01:10 AM
etchhead
Nov 10, 2004 01:25 AM
