Bov help please!
Old May 7, 2009 | 12:01 PM
A4 Sta's Avatar
Default Bov help please!
wuz up guys im new to this site but i need so help. i jus bought a 98 a4 1.8t stick couple of days ago and wanted to thrown in a bov. i bought a turbo xs bov and installed it on the intercooler pipe and caped off the intake pipe is it correct how i did? and when i installed it the bov didnt make any noise at all what do i do??? can some one please help me thanks..
Old May 7, 2009 | 12:13 PM
2fast4u66's Avatar
does the turbo surge? Did you install the vacuum line? To many washers (to tight)?
Old May 7, 2009 | 01:08 PM
redline380's Avatar
Legal Moderator
please read newbie thread first. https://www.audiforums.com/forum/audi-a4-8/newbie-guide-version-2-a-80968/
most people will tell you that you cant run a bov on a closed loop turbo system, some say its ok. personally i dont think there is any reason to run one. why even risk detrimental affects to your enigine just for sound? on the other hand, from the reasearch ive done, the best kind of bov to run is an adjustable one, like a forge 004.
looked on their website this is exactly what it says
"Audi/VW 1.8T Type H Kit (H-1.8T) US$39.00
Allows you to install a BOV-H or BOV-H-RFL to a any Audi or VW 1.8T. Blow Off Valve sold separately. NOTE: Some 1.8T engines respond poorly to venting to atmosphere. Therefore, TurboXS recommends using the RBV-25 vented back to the intake."
Old May 7, 2009 | 01:24 PM
ghost6303's Avatar
it takes a lot of playing with the BOV to get it to run correctly. unless you have a need to vent much more air then a DV can handle, its easier and probably better to just stick with a DV configuration.
Old May 7, 2009 | 01:59 PM
A4 Sta's Avatar
the car runs perfect but the valve does make anynoise??
Old May 7, 2009 | 02:00 PM
A4 Sta's Avatar
i meant DOESNT* make any noise
Old May 7, 2009 | 02:01 PM
ghost6303's Avatar
would you rather your car run crappy and make a woosh noise or run good and quiet?
Old May 7, 2009 | 02:15 PM
A4 Sta's Avatar
its not running crappy right now..so what bout a diverter valve?
Old May 7, 2009 | 02:28 PM
A4 Sta's Avatar
or could having a stock intake be a problem too?
Old May 7, 2009 | 02:33 PM
b5audi1.8t's Avatar
i agree with too many washers prolly not running enough boost to make the bov open it should have came with other springs or washers eaither take washers out are put in a less stifer spring
