BOV/Waste Gate sounds?? Stock A4
Old May 13, 2008 | 10:38 PM
Apdl's Avatar
Member
Default BOV/Waste Gate sounds?? Stock A4
Hi all once again
here is my most recent topic where i was having serious problems! https://www.audiforums.com/m_883277/tm.htm (suppose I outta add it)
I replaced the Fuel Filter and after some good ole time it was runnging again! this time no limp mode! but there still is a CEL I am gonna have it VAGed tomorrow over lunch
My questions is why am i hearing a BOV when i let off under boost?
My guess is a leak but where?
As always thank you alll for your help
Old May 13, 2008 | 11:19 PM
Apdl's Avatar
Member
Default RE: BOV/Waste Gate sounds?? Stock A4
I just got back from another spin
I did notice the sputtering only this time there was a hissing squeaking sounds with it
when the sputtering stped the noise stoped, is this a leak issue?
sorry to dump all of this one you I hope i am being clear
Old May 13, 2008 | 11:31 PM
aeroman28's Avatar
I had an issue with a hissing sound almost a loss of power when I hit the gas. My engine did throw a code of running to rich or too lean. The problem was that my turbo inlet pipe that i had replaced earlier came loose. My O-Clamp came off and there was just that "BOV" sound. Check the turbo inlet pipe that could be the case. Let me know if this helps.
Old May 14, 2008 | 12:13 AM
Apdl's Avatar
Member
Will do thanks
phatboyfromla
Dec 11, 2010 12:54 PM
nits77
Jul 23, 2008 06:30 PM
theguy1084
Jun 26, 2007 11:12 PM
beast a4
May 4, 2007 09:43 PM
True_Pinoy
Aug 3, 2006 05:07 AM
