brake lights stay on/cruise doesnt work with headlights on
Old Jan 20, 2009 | 08:47 PM
SuperSquid's Avatar
Default brake lights stay on/cruise doesnt work with headlights on
My brake lights work perfetly fine when my headlights/parking lights are off.
If I switch either of them on the cruise control dies, no functionality at all and the brake lights come on and stay on.
any ideas? anybody?
Old Jan 20, 2009 | 08:50 PM
AudiTurbo's Avatar
Exact same thing happen to me!! Make sure you don't have a one prong bulb in a 2 prong spot somewhere!!
Old Jan 20, 2009 | 08:51 PM
SuperSquid's Avatar
the cruise control thing too?
Old Jan 20, 2009 | 09:01 PM
AudiTurbo's Avatar
Yep! Mine wouldn't work with headlights on. Also when I hit the brake the from corner light would light up!
Old Jan 20, 2009 | 09:13 PM
SuperSquid's Avatar
the front driver corner light? damnit! that is related to this too? will be nice to solve all of this at once!
ok so i just went out and checked the brake lights. I will try to make this as clear as possible, feel free to ask for clarification if I confused you anywhere.
I have a black panel that pops out of the back of the tail light.
It looks like it has spaces for 4 bulbs.
Currently I only have 3 bulbs in each side.
the open slot on both sides would be the inner most opening.
1) should I have a bulb in there?
2) if so, clear like the other 3? dual filament or single?
On the PASSANGER side, of the 3 bulbs that are in the panel I have 2 dual filament and 1 single filament.
On the DRIVER side, of the 3 bulbs, ALL 3 are SINGLE filament.
I would say you nailed this problem down for me, thanks.
Now to get me squared away, where should I have single and where should I have dial filament bulbs?
Old Jan 20, 2009 | 09:22 PM
AudiTurbo's Avatar
The top is just the rear fogs.
Look inside of the panel and you will see if it needs a single or dual bulb.
Hope this works
Old Jan 20, 2009 | 10:04 PM
SuperSquid's Avatar
actually the tops are the turn signals, the inner bulbs that were missing are the rear fogs. But since I never really specified that i have a '96 that could easily be different for a different year.
I had enough bulbs to reconfigure them so that everything works except the rear fog lights. i would need to buy 2 new bulbs for those.
but now the tail lights/brake lights work as they should across the board, the front marker light doesn't come on anymore when i hit the brakes with the lights off, the cruise works when the lights are on, and the right hand turn signal no longer blinks double time.
Problem solved!
thanks a lot!
chip
Oct 31, 2017 02:26 AM
SFF900
Sep 12, 2012 06:11 PM
03A6owner
Oct 21, 2007 04:03 PM
Blown87camaro
Aug 25, 2007 06:51 PM
oleh
Oct 6, 2006 05:55 PM
