brake pads worn light..bad sensor/connector?
Old Apr 9, 2009 | 09:39 AM
Pa Matt's Avatar
Default brake pads worn light..bad sensor/connector?
Hey guys, I'm picking up a 2001 audi a4 1.8t quattro on Monday. It has the brake pads worn light on in the control center. When I look at the pads, they look new and my landlord(who im buying it from) says they were recently replaced. He said when they were done, he was told the drivers side front brake pad sensor connector was bad and needed to be replaced. Where can I find this? Is it simple or a PITA? I'm gonna check on ecstuning.com, but wont have time to get under the car just yet. TIA
Old Apr 9, 2009 | 11:32 AM
Pa Matt's Avatar
Okay, so I had a few minutes to pull the wheel off. The sensor connector off the brake pad is there, however, there are two wires taped off from the cars harness that should have the connector on that side...guess I need to find one of those and solder it...
Old Apr 9, 2009 | 12:08 PM
never_enough's Avatar
best bet would be a salvage one. clip it off then wire it up.
Old Apr 9, 2009 | 02:59 PM
Pa Matt's Avatar
yeah...thats what im thinking. I've messaged a few people parting out a4's to see if they would help out.
Old Apr 9, 2009 | 03:03 PM
brrman's Avatar
Same thing happened to me - the sensor connector on the car was cut and now only the wire is left there. I just connected the 2 wires to close the circuit and the warning light went out.
Old Apr 9, 2009 | 04:37 PM
since they theoretically burn off at the same rate. if you have one good sensor you could close the one and use the good one still. or get a cheap replacement.
Old Apr 9, 2009 | 07:32 PM
Pa Matt's Avatar
i found a connector for $5 shipped! but yeh, thats a good idea too. What happened to good old fashion squealers and looking at it to see if it needed to be replaced?lol
Old Apr 10, 2009 | 11:06 AM
hiwords's Avatar
hey matt where in PA are you? there's a bunch of us in binghamton and we're always recruiting for more people to join in.
Old Apr 10, 2009 | 07:11 PM
Pa Matt's Avatar
I'm in Scranton, PA which is like 45 minutes from Binghamton! Vitamin Dlicious on AIM if you use it.
Old Apr 15, 2009 | 10:31 AM
Pa Matt's Avatar
I just looked and both passenger/drivers side connectors are gone. The wires are wrapped around eachother and heatshrunk together. Why is my brake pad warning light on?
