brake problem.
Old Jan 4, 2011 | 05:11 PM
Wilsss's Avatar
Default brake problem.
already replaced master cylinder and rebuilt booster. and my brakes the pedal when the car is turned off, they work. (the pedal is hard and doesnt hit the floor). when car is on, the pedal goes all the way in and an air sound is heard... any ideas????
1.8 t
Old Jan 5, 2011 | 09:59 AM
DoctorMemory's Avatar
Sounds like either the booster or a vacuum leak. Can't imagine what else would be related to the engine. Have you verified that the brakes are actually working with the engine off, or just that the pedal is hard? What happens if you disconnect the vacuum line from the booster?
Old Jan 5, 2011 | 03:15 PM
Wilsss's Avatar
thanks for replying. yes the brakes work. and when i take out the hose, the car turns off
Old Jan 5, 2011 | 03:57 PM
abnormal_b5's Avatar
you need to plug the hose when you take it off! if not, like you said, the car will turn off.
try it again with the hose plugged somehow
boosted517
Oct 13, 2020 11:30 AM
mpdc_1
Dec 28, 2007 01:05 PM
DavidElvin
Apr 18, 2007 02:52 PM
Dudek12
Dec 18, 2005 11:48 PM
west2005
Nov 7, 2005 07:36 PM
