Brakes building pressure and holding, locking up! Urgent help for Student needed
Old Jan 12, 2013 | 05:42 PM
vtraudt's Avatar
Default Brakes building pressure and holding, locking up! Urgent help for Student needed
1998 A4:
A local student called me today (needs to leave tomorrow 6 am for 8 hour drive to college).
He is too far away for me to hook up VAGcom today.
His brakes are locking up after a few minutes of driving!
He already changed:
- ABS pump
- ABS module
- Master brake cylinder
Any ideas what might be causing the system to build pressure and HOLD the pressure?
I advised to take the ABS module connector off (hoping that this will stop any gremlins that tell the system to BUILD pressure).
ANY QUICK HELP, SUGGESTIONS, TIPS much appreciated.
Old Jan 12, 2013 | 07:36 PM
meloman's Avatar
Originally Posted by vtraudt
1998 A4:
He already changed:
- ABS pump
- ABS module
I had this happen to me and it was the brake pedal itself. The "nut" that connects to the rod was loose and after tightening it up everything was fine again.
Old Jan 13, 2013 | 08:13 AM
vtraudt's Avatar
Interesting, will check.
But how can that loose nut keep the hydraulic system under pressure?
How can it build pressure on its own (foot not touching the pedal)?
QUOTE=meloman;1419797]I had this happen to me and it was the brake pedal itself. The "nut" that connects to the rod was loose and after tightening it up everything was fine again.[/QUOTE]
Old Jan 13, 2013 | 10:56 AM
bshusted's Avatar
Are all of the wheels locking up, or just one? I've had just the latter on some old cars I've worked. The internal liner in the flexible brake lines can collapse and behave as a one way valve. It will seem to bleed fine, but when you press the brake pedal, the fluid cannot go back.
To diagnose the problematic wheel, jack it up. Press the pedal a couple of times to build pressure and then open the bleeder. If fluid comes shooting out and the hub is able to rotate again, you've found the problem.
Old Jan 13, 2013 | 12:42 PM
meloman's Avatar
[/QUOTE]
For me, everytime I pushed the brake pedal down it wasnt coming back up all the way because it wasnt tight enough, thus not letting out all of the pressure each time and because of that it built up and all 4 would stick.
Is the master cylinder still good?
Old Feb 21, 2020 | 03:15 PM
amnazid's Avatar
Banned
I have 5-6 lectures per week - not more, often - less. I spend way too much time reading different articles. I usually have 2 tutorials a week, for each you need to write an essay up to two thousand words. An essay needs the answer to a bunch of questions that no one can answer - for example, what makes HIV such a successful pathogen. The student's task is to find his answer to this question, based on the available experimental data. I`m so sick of it. Guys who ordered essays https://bestessay4you.com/ online? How do they do such tasks?
Old Jun 9, 2022 | 02:21 PM
furlamotry's Avatar
I really liked the musician Tupac Shakur. I decided to write my own essay about him. I was looking for a lot of information about him and found a site, there are examples of Essay On Family Tree By Tupac Shakur and then I found so much useful information for my essay that I almost wrote it, I didn’t even think that he had such an interesting biography, what a pity that he died. But I think that soon I will release my essay on the net, we remember our favorite singer.
Old Jul 28, 2022 | 07:35 PM
Martin Seebach's Avatar
Default hyperextending piston?
If pads been ground down and rotor also ground far enough it can extend the piston can just past lip and get stuck. I've had this happen on other car/truck. Should that be the issue rebuild the caliper and have someone who knows how to QA machined work verify the column piston rides in is clean and meets height spec. Or get new one. That would keep the pressure on and lock up a wheel.
activeautosports
Jan 10, 2009 02:39 AM
whitejeepXJ
Dec 11, 2007 06:01 PM
NorthernComfort
Sep 19, 2007 07:54 AM
dornier
Oct 27, 2006 07:21 PM
