Bumper pieces missing under headlights
Old Nov 19, 2011 | 05:25 PM
mctruth3's Avatar
Default Bumper pieces missing under headlights
On our A4's bumper there is a small elevated section on the top part of the bumper right under each headlight. I bought mine with those pieces missing. Instead there are holes in those two places. My question is whether the previous owner cut those pieces out or are do they come off for a purpose. I was looking on ebay to try to find them and couldn't so I was thinking they just cut the bumper, but for what reason?
Also on a side note I bought the lower door molding for the front drivers side door and put it on no problem. Than I look at the back door molding and notice it's out a little so I go fiddle with it and the molding breaks off. Now I see why the front one fell off, they seem to deteriorate on the inside. Had I known would have bought the front and back all at once...
Old Nov 19, 2011 | 05:44 PM
Dallas09's Avatar
To answer the first part of your question: those covers are to cover the headlight washer spray nozzles, which once activated, rise from those holes and spray the headlight. They are easily removable when those nozzles are still in place. However, Ive never seen this system working on any A4, and if you dont see any nozzles, they probably removed the system. If the nozzles are removed, there is no where for the caps to attach to.. I JB welded mine on but it only lasted about a year before they fell off.
Old Nov 20, 2011 | 06:34 AM
jonbonesjones's Avatar
Moderator
dallas09 - not true come to MD ill show you working ones. most useless feature of our cars. ever.
Old Nov 20, 2011 | 06:35 AM
Moderator
dallas09 - not true come to MD ill show you working ones. most useless feature of our cars. ever. get them working and flip them around ******* cutting you off get sprayed
Old Nov 20, 2011 | 12:36 PM
audiaxel's Avatar
Mine work too! I've definitely thought about turning them around...
Old Nov 20, 2011 | 12:40 PM
cincyTT's Avatar
I'm make believe
The only way they are helpful is if you have deicer in the ww res and it starts snowing. But still mostly pointless
garrett490
Apr 15, 2011 12:41 PM
numlock4045
Feb 9, 2011 09:59 PM
cummins990
Nov 22, 2010 08:06 AM
harperman89
Mar 2, 2010 10:58 PM
Cranky Bastard
Apr 21, 2007 02:29 PM
