A/C low pressure line damaged?
Old Aug 12, 2009 | 07:37 AM
Muffin Man's Avatar
Default A/C low pressure line damaged?
In March ‘09 a recommended local shop replaced my ‘98 Audi A4 A/C compressor (it had not failed, yet, only was making very loud noise when on), now 5 months later the system only blows warm air. Shop says they need to replace the low pressure line since “something” over time rubbed a hold in it allowing all the liquid to leak out. Shop says vibrations from driving over potholed roads could have caused this. I’m thinking they did not do something right when they replaced the compressor. Is it possible their explanation is correct? Should I be taking my car somewhere else for repair?
They also said while they're in there, I should also replace the high pressure line though it is not presently damaged. Sounds like a good plan or not? Total estimate is $900 to replace both low and high pressure lines including refrigerant/other parts/supplies. Should I be concerned that the compressor or other parts in the A/C system might have been damaged?
Thanks!
foos
May 11, 2015 10:41 AM
audisheri
Dec 23, 2014 05:33 PM
JrTadpole93
Aug 6, 2014 09:17 PM
frizzlefry
Sep 3, 2009 03:38 PM
carlv
Apr 27, 2008 09:17 PM
