Calling all electricians!
Alright, I had my cluster hooked up for a couple days now. When I got in my car yesterday and started it, I smelt electrical smoke. So I immediately unplugged the cluster, and once I got home, I plugged in a known working cluster. The ONLY thing I get are high beam lights, turn signals, and backlighting. And the HVAC doesn't power on. Any ideas?? Thank you!
All my fuses are good. I pulled out the continuity meter. Terminal 15 is "Switched Battery Positive Voltage (B+) from ignition switch" and in the wiring, terminal 15 doesn't get power. What's the root of terminal 15? Is there a fuse-able link in the system?
Terminal 15 originates at the ignition switch, so if you have power on Terminal 30 (battery +) but nothing on 15 with the ignition switched on, then suspect the switch.
I guess I'll get to looking into it next week, until then I guess I'll have to suffer with driving an EcoBoost F150
It tows our 11K lb. boat no problem, too.
