Calling all electricians!
Old Nov 30, 2013 | 04:12 PM
Clayson's Avatar
Default Calling all electricians!
Alright, I had my cluster hooked up for a couple days now. When I got in my car yesterday and started it, I smelt electrical smoke. So I immediately unplugged the cluster, and once I got home, I plugged in a known working cluster. The ONLY thing I get are high beam lights, turn signals, and backlighting. And the HVAC doesn't power on. Any ideas?? Thank you!
Old Nov 30, 2013 | 04:27 PM
Cybersombosis's Avatar
Check your fuses?
Doug
Old Nov 30, 2013 | 04:47 PM
Clayson's Avatar
All my fuses are good. I pulled out the continuity meter. Terminal 15 is "Switched Battery Positive Voltage (B+) from ignition switch" and in the wiring, terminal 15 doesn't get power. What's the root of terminal 15? Is there a fuse-able link in the system?
Old Nov 30, 2013 | 09:21 PM
turbo510's Avatar
Terminal 15 originates at the ignition switch, so if you have power on Terminal 30 (battery +) but nothing on 15 with the ignition switched on, then suspect the switch.
Old Nov 30, 2013 | 10:10 PM
Clayson's Avatar
Gotcha, that's what I assumed but wanted to be sure. Now, wasn't the ignition switch recalled awhile ago?
Old Dec 1, 2013 | 10:23 AM
A4TurboGuy's Avatar
When you smell smoke, it's bad!
That's all the advice I'm qualified to give here.
Old Dec 1, 2013 | 01:53 PM
Clayson's Avatar
Lmao... Thanks Turbo. I guess I'll get to looking into it next week, until then I guess I'll have to suffer with driving an EcoBoost F150
Old Dec 1, 2013 | 11:49 PM
hartsoe1's Avatar
Clayson, how do you like that Eco? I've got a 2003 5.4 screw and I'm thinking.......
Old Dec 2, 2013 | 09:12 AM
Clayson's Avatar
It's definitely more Boost than Eco. I get about 16.5 around town, but I have a tough time driving it in the rain without the back end sliding out It tows our 11K lb. boat no problem, too.
Old Dec 4, 2013 | 10:06 AM
Clayson's Avatar
I have power on all of the key switch wires. What relay should I take a look at, or where should I go from here? Thanks guys!
