can i get rid of the catalayic conveter on can i cut it off ????
is it better to keep it on or can i cut it of ? well it mess up the car with the back pressure you have to have or what should i do any suggestions help please ...
RE: can i get rid of the catalayic conveter on can i cut it off ????
test pipe or have the inlet and outlet made to 3" on the stock cat. This will improve flow and still let you pass emissions. The stock cat is already a HF cat and barely looses any whp
well depends on where you live. in cali, you wont pass smog unless you have an actual cat in it, but if you have quattro, find a place that doesnt have an AWD dyno like in folsom, and they just rev your engine so it doesnt get run under load. This makes it super easy to pass smog
i removed mine and put decat pipe on but have to remove and refit cat evry year for MOT test (UK) but the way i look at it a new cat is £300 here so not using it apart from when test is due saves it breaking and having an expensive bill. dont mind if the decat pipe rots and needs replaced as they are cheap
well i live in florida and theres no tests here but i just wasnt sure if its gunna mess the motor up with the back pressure without the cat ,so i can cut the cat out and the resinator out and have no problems
