Can you tell me where these go?
Old Jan 29, 2015 | 06:04 AM
seabee1164's Avatar
Default Can you tell me where these go?
Im doing heater core swap and putting things back together, But I cannot seem to figure out where these two plugs go. Any ideas?
Old Jan 29, 2015 | 11:11 AM
A4TurboGuy's Avatar
Can you rotate the picture and highlight/circlet the items you're talking about?
Old Jan 29, 2015 | 11:36 AM
seabee1164's Avatar
I am at work right now but will rotate and mark it when I get home. It is the brown and black plugs. The brown plug has a single wire to it. The black plug is wired in a series from a wire coming from the climate control. If that makes sense.
Old Jan 29, 2015 | 12:53 PM
MetalMan's Avatar
That's a pre-facelift (quite different from facelift).
The brown connector I believe is only used for the stock head unit, as a ground.
I'm guessing that black connector connects to the off-white-colored fan/motor that attaches to the end of the rectangular duct piece that is just behind/below the black connector in the picture.
Old Jan 29, 2015 | 01:37 PM
seabee1164's Avatar
Not sure what you are talking about about facelift but I already have the fan plugged into something. Maybe the wrong thing?
Old Jan 29, 2015 | 02:44 PM
normal's Avatar
can't help with your original question. But I believe the 'facelift' mentioned is a reference to where/when your B5 falls within changes made in B5 series. People will say their b5 car is 'prefacelift', etc.
I can't explain the changes without searching/googling them.
Old Jan 29, 2015 | 04:17 PM
MetalMan's Avatar
The facelift reference was to A4TurboGuy, I'm not sure how familiar he is with pre-facelift dash wiring. But facelift means the car is a 1999.5 year or later, anything before that (like your car) is pre-facelift.
Can you take a picture of a picture of which harness the black connector's wires go to? And in that picture maybe show which other connectors go to the same harness?
Old Jan 29, 2015 | 06:47 PM
seabee1164's Avatar
hope this helps
Old Jan 29, 2015 | 07:51 PM
elduderino200's Avatar
It's gotta be something back in there. I did the heater core a while back and was scared I would miss a connection but I ended up finding homes for everything eventually. Is it too late to pull out the dash connections/climate control/radio assembly again? Just to look at and make sure you didn't miss anything.
Could it BE the radio?
Old Jan 30, 2015 | 01:42 PM
seabee1164's Avatar
Well the radio is not factory. I bought the car that way. I thought I made sure that I took note where every plug went. It may be a possibility that these two were not plugged into anything.
