Can't find vacuum lines on 2.8
Old Apr 9, 2011 | 08:24 PM
Lornnn's Avatar
Default Can't find vacuum lines on 2.8
I've been scouring the forums, google image, youtube, etc and can't seem to find the vacuum lines. I'm in a 98 A4 B5 2.8 and there appears to have been a few changes made by the previous owner...
Old Apr 10, 2011 | 08:31 PM
KinkySlayer's Avatar
there should be a diagram under your hood
Old Apr 10, 2011 | 08:39 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
I can see 4 vacuum lines in the pictures you posted. They are the fraying cloth lines.
Old Apr 11, 2011 | 08:48 AM
chocalotstarfish's Avatar
Super Moderator
I drew on at least 6 I could see I'm sure there's more.
On the yellow one on the other side of the check canister (blue/black) is another vac line leading off of it.
Old Apr 11, 2011 | 09:06 AM
Super Moderator
Edit I didn't see the other picture this one shows more.
Old Apr 11, 2011 | 10:27 AM
CCA4's Avatar
This is what my 12v looked like after i replaced all the crusty old vac lines. I obviously used blue line so they should be pretty easy to pick out
EDIT: Keep in mind that your 30v is going to be slightly different, the pic was just for reference. Don't forget to replace the hard line that runs under the intake mani to the vac reservoir.
Old Apr 12, 2011 | 03:28 PM
Lornnn's Avatar
Thanks a lot, guys. I'm definitely going to be replacing these. CCA4, what kind of tubing is that and where could I find it?
Old Apr 12, 2011 | 03:42 PM
CCA4's Avatar
Its 3.5mm silicone vac line. ECSTuning has it, but i'm sure you could find it cheaper someplace else
Old Apr 13, 2011 | 08:40 PM
cruzer555's Avatar
Hey guys, how hard is it to replace the lines? Also how expensive? I'm looking into buying a 30V V6 with fraying lines that seems to have a leak because it idles high when cold started and then settles to a rough idle after driving around a while.
Old Apr 13, 2011 | 09:52 PM
Super Moderator
Pull off and put on. Maybe $10!
TheycallmeClutch
Feb 7, 2011 12:32 PM
Khardysius
Oct 13, 2010 09:29 PM
Tourbo24
Apr 27, 2010 04:53 PM
y^0
Apr 8, 2010 08:52 AM
jblum
Feb 21, 2005 12:39 PM
