car check up!
hello everybody i just recently owned an 2001 audi a4 quattro manual with 117000 miles..now im planning to have the car check up..and fix or maintain what every i need to..should i bring it to a local auto place such as pepboys? or i will be better of going to an audi specialize auto shop? i want to get the whole car check out basically want to fix whatever is wrong with this car..so far the car rides smooth to me but i just want to keep everything on this car perfect so i wont have to run into any trouble later...also the previous owner said that this car ran on royal purple oil? i never heard of that so is there any way i can change that back to fully synthetic? if not where can i go to change this type of oil? thanks! all the help would be needed!
you should definitely not take it to a pepboys or anything similar... find a good independent german auto repair shop and plan on spending too much on everything. Have them do an inspection and give you a list of everything they recommend and then invest a good amount of time researching everything they recommend on these forums and then find the parts cheap online and do the work yourself using the diy threads
yeah shiiit cost alot at dealership!
as soon as it warm up (20degree outside) i'm do the timing belt with the water pump and w.e else need to be change. add my fmic tooooo while i have everything off.... maybe change to a k04 turbo??
i heard that once to change to synthetic you cant go back to normal oil?
