Car starts but then stalls
Old Apr 21, 2016 | 12:41 PM
Russ Pederson's Avatar
Default Car starts but then stalls
Hey new problem here...2000 a4 quattro 1.8t. Drove to the store this morning, car worked fine. When i came out of the store i started the car and it started but after about 20 seconds it turned off on its own. The car will continue to start but then dies within 5 seconds. Any ideas?
Old Apr 21, 2016 | 04:48 PM
elduderino200's Avatar
Any check engine lights or codes?
Could be a ton of things but initially I'm thinking coolant temp sensor.
Old Apr 21, 2016 | 06:10 PM
No cel on...im thinking because it wont run long enough to set a code...?
Old Apr 21, 2016 | 07:05 PM
It should be immediate if something goes wrong. When my car didn't start due to a bad crank position sensor, it threw the code when I was turning it over.
Old Apr 21, 2016 | 08:07 PM
My friend is bringing his code reader over tomorrow so ill see if it has anything on it but now instead of the car starting for 2 or 3 seconds before stalling, it just wont start at all. It turns over fine but just wont start.
Old Apr 22, 2016 | 12:04 AM
Sounds like the crank sensor. But that would throw a code.
Make sure you've got fuel. Doesn't seem like spark or air would just stop flowing for any reason. Fuel pump might have gone bad.
Old Apr 22, 2016 | 12:43 AM
Well i pulled the fuse panel to check the fuel pump relay and i put my finger on it when i tried to start the car and i could both hear and feel it click so i think the relay is fine.
Whats the best way to test a fuel pump...is there some kind of fuel pressure test port located anywhere?
Old Apr 22, 2016 | 01:15 AM
Unfortunately no test port that I know of.
I can't attest to this because my hearing must be bad, but evidently you can hear the pump flip on and prime when you turn the key to 'on' (i.e. not turning over).
Too be honest I had to take a fuel line apart and t in a pressure gauge to test mine. Granted I was testing the pressure and not just whether it was on at all so you might not need to do so. I would just google 'bad fuel pump symptoms'. Sorry I can't be of more help here. I know a LOT of people know more about bad fuel pumps than me.
Old Apr 22, 2016 | 01:44 AM
Well im also seeing alot of the these symptoms point to the crankshaft position sensor like you were saying, based on other forums, so i might try that first
Old Apr 22, 2016 | 09:37 AM
A4TurboGuy's Avatar
+1 (PS: I miss the hell out of Seattle).
I can't attest to this because my hearing must be bad, but evidently you can hear the pump flip on and prime when you turn the key to 'on' (i.e. not turning over)......
+1
Just pray it isn't the main bearings!!!
