car won't starttt
Old Jan 31, 2010 | 10:18 PM
  #31
Rowland2004's Avatar
I had a simular problem with my 98 Avant 2.8Q with only 68k. It would turn and turn and turn but not start. So i listen for the fuel pump and the pump would not turn on. So next i jumped the fuel relay and heard the pump, then replaced the relay but still no start...
So the only other thing that would turn on the pump other then the relay would be a signal from the ECU. So i sent out the ECU and they found pin 8 & 9 being bad which was with the fuel and injectors. So i got a rebuilt ECU and put it in 3nights ago and had to turn the key quite a few times to get fuel and then it would start to start a little more and more. Then Roooom and some black smoke lol
It started right up and its been cranking up like it use to.... Maybe this helps.
Cause another sign of the ECU not working would be no CEL when you turn the Key on..... Good luck...
Old Jan 31, 2010 | 10:22 PM
  #32
ImTheDevil's Avatar
Holy crap onepoint8tee is alive?
Old Jan 31, 2010 | 10:29 PM
  #33
kayakman13's Avatar
Sounds to me like its time to juice up that starter. If the starter works fine, but the engine still fails to start, then its time to take it in to a shop.
Old Jan 31, 2010 | 10:34 PM
  #34
kayakman13's Avatar
Good suggestion Rowland!
Old Feb 1, 2010 | 07:56 PM
  #35
Andrew149's Avatar
Why not roll on some 2x4's and than lift the car
Old Feb 1, 2010 | 09:00 PM
  #36
aledelic42's Avatar
a bad ecu could be a possibility. I'm not sure what kind of lift the guy has at his place so I don't know. I called him today but they're packed until next week now so I guess I'll wait til then. may be checking out an avant tomorrow..
Old Feb 20, 2010 | 01:30 AM
  #37
mikeross's Avatar
Member
Originally Posted by kayakman13
Why can't cars just tell us whats wrong with them?
Attention esteemed owner! Errors detected in the Fourth Quadrant! Errors are as follows:
"My starters fucked up man, I dunno, it feels like a loose connection! Just tighten this bolt. See? To the left there. Thats the one."
If only... if only...
Haha.. That was funny. Yeah I agree. I hope cars would actually tell what the problem is. So we would not actually opening up the car, checking the whole thing and give our own diagnoses.. Last week my distributor wires got disconnected without me noticing it.
Old Feb 20, 2010 | 10:37 AM
  #38
bradtyler02's Avatar
So here we are, a couple weeks later... what's the deal with the car aledelic? Did you ever figure out what happened?
Old Feb 23, 2010 | 11:43 PM
  #39
Msnickbroderick's Avatar
Actual WIZARD
Hey if your finally letting it go, PM me and lets talk!
