Central locking issue?
Old Jul 4, 2017 | 02:13 AM
CosmoRotary's Avatar
Default Central locking issue?
I have a 1997 b5 a4 18t. I received the car with a valet key only. I got two key fobs off of amazon that I wish to program. When I open vcds and go to the "central locking-35" it shows two keys are saved. When I go to "adaptation" and select channel "00" to reset the key fobs it says ok. when I go to "measuring blocks" on channel "003" it still shows 2 keys saved. When I go to "adaptaion" and try channel "01" or channel "21" it just gives me an error. Is there another way to reset the central locking unit?
Old Jul 4, 2017 | 04:15 PM
A4TurboGuy's Avatar
You don't need to reset anything. Just leave those two keys in there and begin your keys using the first number above the highest stored number and you should be fine. If that doesn't work, check FOB compatibility.
Old Jul 4, 2017 | 04:31 PM
Under "adaption" it says error on the channels? The keys are from amazon "Combo Compatible with Audi 4D0837231E, 4D0837231P (2 Pack)" when I try without vcds with one key in door and another in ignition nothing happens. I get no flash or beep just the locks locking when I turn the key.
Old Jul 5, 2017 | 06:38 PM
A4TurboGuy's Avatar
Then those keys are incompatible and won't work. I don't know why they do that. It's so frustrating. I only have one key for my silver car and two for my black car. They're both 2001 8D B5's and they still won't migrate over.
a3turrell
Jun 4, 2023 11:15 PM
A4TurboGuy
Jun 18, 2014 08:41 AM
Indylotay
Jan 15, 2013 02:08 AM
steven.hardy
Apr 13, 2011 09:00 PM
bier ist gut
Dec 23, 2008 10:28 PM
