Charging problem 99 1.8T
Old Nov 2, 2010 | 01:25 AM
Handicappedracer's Avatar
Default Charging problem 99 1.8T
New member here and I need help. We've replace the alternator twice. ALternators test OK on test benches but the charge is not going into the battery. Can anyone shed some light on this? Specifically, where does the voltage wire go to? Starter connection or ECU or where? I would like to check the voltage at the other end of the wire.
Old Nov 4, 2010 | 12:32 AM
Can anyone tell me where the 12V leaving the alternator terminates. I'm only getting about 10 amps going into the battery. Something is draining the charge from the alternator. I have to do a wire trace to look for chafing or corrosion. Any help on where the charge from the alternator goes would be helpful.
Old Nov 4, 2010 | 01:35 AM
Msnickbroderick's Avatar
Actual WIZARD
1. read the faq
2. find the FULL service manual in there
3. Download
4.look in the shop manual
jeff else
Oct 14, 2014 04:02 PM
jeff else
Oct 11, 2014 04:48 PM
frankie77
Jul 20, 2012 10:21 AM
4plaay
Feb 24, 2010 01:57 PM
audi_tt_4u
Aug 28, 2008 09:35 PM
