Check Engine Light
Old Jul 17, 2008 | 06:31 PM
bauer1185's Avatar
Member
Default Check Engine Light
My check engine light came on this morning and I went to auto zone to get the code check code P1137 came up it said something about fuel meter. The definition said "Long term Trim. Add. Fuel B1 system too rich." Explanation: Failed MAF. What could be the main problem and what could I do to fix it. It said three causes could be High Fuel Pressure, canister purge solenoid stuck open, or failed HO2S.
Old Jul 17, 2008 | 06:48 PM
pimphell's Avatar
Default RE: Check Engine Light
you could try cleaning it first with maf cleaner?
Old Jul 17, 2008 | 10:38 PM
audiltr's Avatar
the first out of the four options is usually the problem. i agree with pimphell try cleaning the maf Start with the basics
Old Jul 18, 2008 | 12:04 PM
meanmuggin's Avatar
well you can do that, auto zone has a MAF cleaner and it works and if that dosent fix it then get a universal o2 sensor from the store and it actually works better than the original.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
