Check Engine light 4 codes
98, 2.8,5V, the codes are 1338, 1138,1136 and 0411. Two things I put a can of old gas (from summer) in and also drove home in the snow and got a lot of snow up in the grill. Next morning the check engine comes on. Are the codes related to each other? Where should I start?
Sounds like cam sensor and a vacuum leak to me. If you can, go to a pick and pull and grab a cam sensor. Make sure they have the same serial on them, and the yard shouldn't cost you more than $5-10.
Next is try to find the vacuum leak. Not much else you can do other than stick your head in the engine compartment while the car is running and listen for the leak. I've heard about spraying WD-40 or something in the compartment and look for bubbles (but I can't remember what substance they sprayed, so better not try that without knowing).
inkhaton
Aug 16, 2012 03:37 PM
