Check engine light codes help!!
Old Oct 19, 2009 | 06:23 PM
Buttershxc's Avatar
Default Check engine light codes help!!
I drive a 98 b5 2.8 and just got the codes scanned today and here is what they are.
p1138
p1136
Now it seems my check engine light is intermittent. When its warm in the summer it wont be on for at the four months. Now as soon as it gets cold it comes back on. I have it checked several times and it seem they always tell me something different. But this was two advanced auto parts today that gave me the same codes. So can someone out there help me so I can get this damn light to turn off. Also my brake light and my air bag light is constantly on. Anyone know why????
Help??
~Aaron
Old Oct 19, 2009 | 06:51 PM
TeeterTawter's Avatar
17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
Possible Solutions
Check Mass Air Flow (MAF) Sensor
Check Fuel Pressure Regulator
Check Fuel Pump
Check Intake/Exhaust System for Leaks
Check Secondary Air Injection for Leaks
Check Vacuum Lines for Leaks
P1138 17546 Long Term Fuel Trim Add, Bank 2 System to Lean
Check Catalytic Converter
Check Fuel Injectors
Check Fuel Pump
You are running Lean get it fixed.
just so you can narrow it down, I bet you have a faulty maf or have vacuum leaks somewhere in you system.
Air bag light you need a vagcom to diagnose which one is triggering it
RedA4guy
Mar 15, 2014 08:59 PM
rb12
Apr 27, 2010 01:14 AM
TimmyTT
May 18, 2008 10:08 PM
Mattchef
Sep 7, 2007 06:10 PM
