check engine light driving me crazy please help!!!
Old Sep 26, 2013 | 01:31 PM
peterbr1723's Avatar
Default check engine light driving me crazy please help!!!
I have been on working on clearing the code on my 97 A4 1.8T, 100,000 miles. I replaced the MAFS, checked the vacuum all the lines look good to me. After replacing mafs I reset the code , drove it some, and now the OBD II reader says P1136 pending. What else can I change or do?
Old Sep 26, 2013 | 01:34 PM
CCA4's Avatar
P1136 is long term fuel trim, so it should tell you if it's running lean or rich. The fix will depend on which problem you're having.
Old Sep 26, 2013 | 03:42 PM
It says system to lean.
Old Sep 26, 2013 | 09:45 PM
Kamil`'s Avatar
I am assuming the 02 sensor is reporting Lean because you have some type of leak. If it was reporting rich then that would mean there is too much unburned fuel in the exhaust flow.
J_Llamas74
Apr 26, 2013 08:26 AM
sejman
Sep 18, 2010 04:49 PM
parlayin
Feb 10, 2010 12:33 PM
blanthony
Mar 25, 2006 01:18 PM
