Timing off 1 tooth? How to check? How to fix?
Old Sep 23, 2013 | 09:36 PM
lukedorris's Avatar
Default Timing off 1 tooth? How to check? How to fix?
2000 1.8t atw... Swapped my timing belt, now I have a rough idle and no power on the bottom end (less than 2.5k rpms). Runs great past 3k rpms. All things point to timing off a tooth. How do I check this? (Btw, no CELs) Can I check this by just popping off the timing belt cover, and if so... how? Once I confirm I am off a tooth, how do I fix this? Please, be detailed... this would be my first attempt at adjusting timing. I assume I will have to remove the timing belt again, which would mean yet another timing belt tensioner... correct? Will I need a timing gun? Are there any tutorials on this? Thanks to all who help!
Old Sep 24, 2013 | 08:12 AM
Huskerbob's Avatar
The teeth don't matter. If you just "swapped" belts and tried to do it by counting teeth you failed. Do a Google search for "audi 1.8 timing belt replacement procedure" and do it over correctly. You will damage the engine if you don't.
I did the search and there are 2 very good procedures with pictures for you to follow. This is not just a matter of swapping the belt and no you won't need a new tensioner. You just have to pin the one you have.
Good luck.
Old Sep 25, 2013 | 11:59 AM
lukedorris's Avatar
Thanks Huskerbob... you from Lincoln? Asking because of the Husker football team
Old Sep 25, 2013 | 05:32 PM
Huskerbob's Avatar
Fremont
Old Sep 27, 2013 | 01:11 AM
lukedorris's Avatar
Nice! I'm in Lincoln. GBR!
rkelsey10554
Oct 19, 2013 10:43 AM
rakort
Oct 8, 2013 08:05 PM
Expplucky
May 29, 2013 07:37 PM
smokn944
B7 Models
Aug 5, 2010 04:30 PM
toto
Feb 9, 2007 01:50 AM
