check engine light results
Old Sep 22, 2009 | 08:38 PM
foamy's Avatar
Default check engine light results
pluged in obd2 scanner while running.
p0455 evap emissions system leak detected. Gross leak/no flow
p1136 long term fuel trim add. fuel bank 1 system too lean
p0301 cylender 1 misfire
p1250 fuel level too low
p0130 O/2 sensor bank 1 sensor 1
i shut off the light and it stayed off but the car is not registered yet and have not drivin it with the light off. where should i start?
Old Sep 22, 2009 | 08:42 PM
Pjbrof's Avatar
Year? Engine?
Old Sep 22, 2009 | 08:45 PM
never_enough's Avatar
Fill the gas tank. replace front o2 sensor if you have the 1.8 front left if it's the 2.8. then swap #1 (closest to the timing belt) and #4 coilpacks and see if the misfire follows. if it does, buy new coilpacks. rescan and see whats still coming up. i've never had an evap problem so not sure there, somebody will chime in.
Old Sep 22, 2009 | 08:47 PM
foamy's Avatar
97 a4 quatro 1.8 turbo
Old Sep 22, 2009 | 09:00 PM
ghost6303's Avatar
just clear the codes and see which ones come back first of all. there may have been old codes stored.
Old Sep 22, 2009 | 09:27 PM
ImTheDevil's Avatar
Yep and even letting the clutch out too much (allowing the revs to go too low) can cause the misfire code. It's a 1.8T so in this case it's a nonfactor but on a 2.8 a bank 1 sensor is passenger side primary, not driver side.
mikeysline06
Nov 4, 2010 10:32 PM
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
blanthony
Mar 25, 2006 01:18 PM
