Check engine load signal
Old Jun 24, 2008 | 11:07 AM
brimhall99's Avatar
Default Check engine load signal
ok so i got vag com and it came up with p1857, load signal: error message from ECU. Could this be as easy as a mass air flow sensor? Has anyone had the same code come up in there car?
Old Jun 24, 2008 | 11:14 AM
hiwords's Avatar
Default RE: Check engine load signal
no it's your ecu. check the harness on it and check the fuses next to it
Old Jun 24, 2008 | 01:10 PM
brimhall99's Avatar
I have had both of those checked, also i had the ECU reset and its still the same problem any other ideas
Old Jun 24, 2008 | 01:45 PM
CRAZYHAWK's Avatar
Do you have a Tiptronic transmission?
Old Jun 24, 2008 | 01:55 PM
techbod's Avatar
its a bogus code due to cold start up and will clear its self
Old Jun 24, 2008 | 02:00 PM
brimhall99's Avatar
but the car rides like **** when i take off fast, its a tiptronic, seems like no boost. I have had a boost leak test, the turbo takin out to see if a bad turbo, any suggestions or is there any way it could be the mass air flow sensor
Old Jun 24, 2008 | 02:56 PM
techbod's Avatar
there must be other fault codes? unless you did upgrades
Old Jun 24, 2008 | 03:13 PM
brimhall99's Avatar
I had it chippped for like a week, then went in to take it off. I got a vag com the next day and thats the code that came up
Old Jun 24, 2008 | 07:36 PM
brimhall99's Avatar
Anyone?
Old Jun 24, 2008 | 07:49 PM
hiwords's Avatar
i'd go back to the place that chipped your car and tell them they gotta fix your car lol
