chip 1st or k04 first?
so guys i am wondering what should i get first the k04 then chip or chip first then k04? i want gIAc since the shop is close to me. i have a 97 audi so it has the weak little k03 not even the k03s .
well they all go together. you need a chip + a ko4 + more to run a ko4 on your car.If your looking for some more speed without spending too much. Chip it
Originally Posted by jonbonesjones
(Post 1400727)
Originally Posted by Subarashī Kao
(Post 1400765)
i was looking at getting the k04 file so i guess i have to have the k04 first to run that because i could be wrong but the k04 on the stock ecu would run just fine but if i get the k04 chip/file i dont think the k03 can run off it.
Originally Posted by CMac019
(Post 1400795)
I believe you could chip the car first with the k03 and then just have the chip flashed over to a k04 file once you purchased a k04... but you might have to send the chip to the company to be flashed over. But I'm not 100% sure so someone should confirm this :confused:
You can run the K04 without the chip. You just won't be getting any extra power.
If you want to chip it first, you can upgrade to the K04 file after you get the K04. In other words, you can go either way. |
(Post 1400797)
(Post 1400881)
wont i get charge more do? i would be paying for the k03 chip then i would hav:De to pay again to get it switch over ? or is this wrong? is it free? am missing something here? lol
I think GIAC is known to give you an upgrade at a discounted price as you progress through your upgrades. If your ultimate goal is the KO4, then yes, you can install the turbo, then go get the chip. However, for the full use of the KO4, you need the PC16 file, which also requires new injectors and FPR.
But, it's become pretty common among people around here that the KO4 upgrade simply isn't enough power for the money, when for a few hundred more, you could get an elim kit, and considerable more power. Just food for thought. |
^^ completely agree. I don't advise anyone to spend money on a k04. If your looking at it because you're on a budget or want quick spool look into the frankenturbo. Basically the same price but good for another 20-30whp.
