christmas year round
Old Jan 25, 2009 | 06:58 PM
turbo kraut's Avatar
Tech Guru
Default christmas year round
trying to clear some lights off the dash, ran a vag, got this
i know why i am throwing the catalyst code, and prob same reason for the o2
VAG-COM Version: Release 409.1-S
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 4B0 906 018 M
Component: 1.8L R4/5VT 0003
Coding: 16201
Shop #: WSC 78641
3 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC
Controller: 8D0 820 043 P
Component: A4 KLIMA
Note: Excessive Comm Errors
Address 15: Airbags
Controller: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06335
2 Faults Found:
01218 - Side Airbag Igniter: Passenger Side (N200)
32-10 - Resistance too High - Intermittent
01211 - Belt Tensioner Igniter: Rear Driver Side (N196)
Address 17: Instruments
Controller: 8D0 920 980 QX
Component: B5-KOMBIINSTR. VDO D13
Coding: 02242
Shop #: WSC 02116
No fault code found.
Address 35: Centr. Locks
Controller:
Note: Can't Synch Baud Rate
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 66666
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 00003
1 Fault Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
Old Jan 25, 2009 | 07:01 PM
CCA4's Avatar
I think the airbag code is caused by a plug under the driver's (or passenger's i suppose) front seat. See ImTheDevil's photo album. I've never heard of the radio antenna throwing a code, nor have i ever seen the "rough road..." code before. Hopefully one of the tech's will be able to help ya.
Old Jan 26, 2009 | 02:43 AM
Dallas09's Avatar
CCA4 is right about the connector under the seat for the side airbag. To get at the seatbelt tensioner you have to remove some trim to get to the connection for that (located by the seatbelt retractor obviously), since both faults are sporadic i would bet on both of them being loose/coroded wiring issues. The other possiblities for bad wiring could be at the Airbag module, or a connector station which is far less likely. Its possible that if you cleaned the connection under the seat and reseated the connector and reset the codes, the seatbelt tensioner might not come back.
You dont have a VAG listed for the ABS module, that might shed a little more light on the rough road signal. The ABS module sends a signal to the ECU when your brakes are pulsing so that the ECU will ignore any misfires from the engine because of a rough road. Not sure if that would throw a CEL or not in itself, but you would need to fix those other issues that you said you know the reason for.
The open circuit for the radio antenna could be as simple as a loose connection at the back of the radio, or it could be a bad antenna. But if your getting reception Id clear it and forget about it becuase it wont throw a light on the dash or anything.
Old Jan 26, 2009 | 08:15 AM
Tech Guru
there is no light for the abs modual cause vag com couldn't talk to it........
i talked to kompressed, and he said it is cause my modual is shot
i think the radio one could be because my radio was on...... i normally get a central lock one with the doors open, but they were closed.....
main thing i was looking for was the airbag........ i always thought the underseat fix, was for something else..... will try that, and thanks for the heads up on the tensioner
Old Jan 26, 2009 | 09:02 AM
hiwords's Avatar
i think the airbag fix was for the front driver's side. i don't remember that well cause it's been a while since i vagged imthedevil's car. i'm the local vag guy lol. either way, i rly hope it's just a ghost code and goes away after you clear it. as for the radio code, i don't think i ever got it when vagging my car with the radio on, i don't think i could vag the car without the radio on lol, gets too boring sitting there
Old Jan 26, 2009 | 11:14 AM
Tech Guru
how do you kill the check engine light?
and the airbag light, i have the $199 version and it lets me clear the history, but not the light
Old Jan 26, 2009 | 11:19 AM
somebody5788's Avatar
That means its popping the code again. You will have to repair it before it will be gone permanently.
Old Jan 26, 2009 | 11:23 AM
Tech Guru
just talked to ross-tech.... he said cause i have a 3rd party cable i have to go in and manually clear it/them.....
Pablo_Ottawa
Dec 30, 2014 01:00 PM
sonsa4
May 10, 2013 08:57 PM
SLIMMACKEY
Aug 4, 2009 12:37 AM
Go_HIN
Aug 23, 2005 07:12 PM
Go_HIN
Jul 25, 2005 05:47 PM
