Cleaning Up the Engine?
Best way to Clean up the Engine bay? Easiest way to get it all cleaned up. can it just like be powerwashed lol cause mine is not very clean. i wanna get it all cleaned up just to get it looking better.
GREEN STUFF !!! just let your engine run for 5 mins, ( or let it get warm) and spray very, very religiously all over everything.... then, take a hose and rince clean... vwalla ! then if needed grab a brush and go over things that still needed help
Doesn't spraying any liquid into the engine bay pose a short risk? Surely a lot of the connections under there for various sensors and such aren't fully water tight to be having gallons of water and solvent poured over them. At least that's what I've heard, I could be wrong.
Car setups are different now, but you're basically looking at the same thing - keep water out of where water doesn't belong, and no troubles. Cover the air intake and if your car is 5 years old or older, cover the coil packs and ignition modules before spraying water into the compartment.
As for shorts, I'd rather know now than have it die in the middle of the street in nasty weather after I've driven through some water.
I would go easy on the water. Cover the alternator/coilpacks/intake. Some water is fine, but I would go bare hose on this one, you don't want to force water in. And no no no on pressure washer, they have a tendancy to squeeze water where it doesn't belong, like say... past your head gasket.
