clicking
Old May 16, 2008 | 12:49 AM
turbo kraut's Avatar
Tech Guru
Default clicking
so recently my car starts clicking........ it sounds like it is coming from the sai or fmic........ what do you guys think it could be?
Old May 16, 2008 | 08:34 AM
david9999's Avatar
Default RE: clicking
You left your watch under the hood.
Old May 16, 2008 | 02:18 PM
Tech Guru
nope, but good try........ anyone?
Old May 17, 2008 | 05:44 AM
david9999's Avatar
My previous note was part joke, part sarcasm.
Noises are almost impossible to diagnose over the net and we will need lots more information.
What makes it worse, what makes it better
Does it only occur when the engine is on?
Does it stopp when the engine is turned off?
Does the noise increase in speed or volume when the engine is going faster? Does it match car speed, or engine speed? If you push in the clutch and reve the engine, does the noise stay the same or increase in speed.
You have to do some work and give us something to work with. Otherwise no one is going to be able to help.
Old May 17, 2008 | 05:45 AM
david9999's Avatar
And letting us know the year, mods, engine, and tranny type as well as mileage wouldn't hurt either.
Old May 17, 2008 | 11:15 AM
Tech Guru
01 A4 1.8tqms: apr 93 oct, m3 spoiler, s4 wheels, rs4 grille, tinted tails/sidemarkers, apr tip, A8 BBK W/ TT carriers, race valve, 004, fmic, euro plate, euro s4 healights, tp/2.5 inch exhaust(resonatorless) into magnaflow muffler, swiss box mod w/K&N drop in filter
some are performance some aren't
also i think i happens more in the colder times........ it just started.... i was looking though and it might be my fan clutch clicking..... i will check that and let you know....... but it doesn't get louder.. when it happens it is constant.... nothing i do makes it start or stop
Old May 17, 2008 | 11:30 AM
david9999's Avatar
If it only occurs when you are driving and happens when you are making a turn, it is likely your CV joint.
If it happens when the engine is running and the car is still it is probably either valves, or cam tensioner.
If it happens after your car is hot and the engine is turned off, it is likely just metal contracting.
Old May 17, 2008 | 04:26 PM
Tech Guru
actually i found it...... but i still need help
i did my tp/wp and fmic and had to pull ym radiator/fan shroud...... there is a wire that goes around the shroud that pulled loose...... and got caught up in the fan and shreaded... it was clicking everytime the fan turned.......
the help i need is a wire diagram for an 01 a4 1.tqms for around the shroud
Ozzy S
May 19, 2013 03:58 PM
swanson22
Jun 10, 2011 01:07 AM
afstud6900
Apr 3, 2008 11:54 AM
shmo
Feb 3, 2008 03:41 PM
308gts
Jan 6, 2008 08:00 PM
