Cluster display
Old Nov 10, 2008 | 01:20 PM
chivo818's Avatar
Default Cluster display
my 97 Audi's check engine light turned on and when i press the check button the MPH things circled with a 1 in the top left corner what needs to be done? Also I cannot get the display to show out side temp,mpg.
Old Nov 10, 2008 | 07:34 PM
CCA4's Avatar
I have a '97 too, what "check button" are you talkin about?
The best thing to do when you have a CEL (Check Engine Light) is to take your car to autozone or advance auto parts, and have it scanned for codes. The guy will tell you the codes, write them down, post them, and we'll help you from there.
Old Nov 10, 2008 | 08:25 PM
somebody5788's Avatar
Can you show MPG there?
Old Nov 11, 2008 | 01:52 AM
chivo818's Avatar
The button under the Tach when I push it the display runs through a diagnostic test after that was done it would display general info.
I have only had the car for 3 weeks it's a 2.8 and runs good overall.
Old Nov 11, 2008 | 08:39 AM
CCA4's Avatar
Interesting. There must have been a couple different dash setups then, cause the button under my tach sets the analong clock. Unless I wasn't pushin it hard enough or somethin?
Edit: I tried it again when I drove into the city just now, and it def. doesn't push in or do anything cool. =/
Old Nov 11, 2008 | 09:47 PM
chivo818's Avatar
To set my clock I pull the post out, when I push in that's when it goes through everything. I will try and get a pic for you.
Thanks for your help.
gdavidson
Sep 28, 2010 09:40 PM
Tourbo24
Jun 30, 2010 08:00 PM
stayfocus18
Sep 2, 2009 02:24 AM
hotgue
Mar 10, 2009 12:01 AM
barryoy32
Jan 15, 2006 11:42 PM
