Code Reader socket
Old Jun 15, 2010 | 11:10 AM
Doug I's Avatar
Default Code Reader socket
'96 Quattro
Where is the socket for the code reader? It's got to be somewhere, but it appears to be well hidden.
Thanks
Old Jun 15, 2010 | 11:18 AM
FASTER's Avatar
Tech Slut
Obd2 is under the dash by the hood pop lever
Old Jun 15, 2010 | 11:22 AM
Doug I's Avatar
Thanks!!
Old Jun 15, 2010 | 11:37 AM
shortyxc's Avatar
Or in the rear ashtray depending on year.
Old Jun 15, 2010 | 01:24 PM
Doug I's Avatar
found it in the rear ashtray
I think I scanned, erased the codes, and rescanned.
It's showing no codes but the dash airbag light is still on. The car had some internal dash work done a few years ago in Al. and the light came on after that. In Al. it doesn't matter - but here it does.
Did I not use the reader correctly, or is there another technique to turning the light off?
Thanks
Old Jun 15, 2010 | 01:54 PM
CCA4's Avatar
check under your driver's seat. There you should see a yellow plug like this: (picture shamelessly lifted from Jeremy's album)
That little bastard gets loose and can trip your airbag light. If the ziptie fix works, the light should go out immediately. BE CAREFUL!
Old Jun 15, 2010 | 03:17 PM
Doug I's Avatar
Thanks for the quick/clear reply
be careful because?
wiggling it can set the bags off?
Old Jun 15, 2010 | 03:28 PM
CCA4's Avatar
I dunno if it would necessarily set the bag off, but do you really wanna find out? lol.
Old Jun 16, 2010 | 03:56 AM
Dallas09's Avatar
If you didnt find any codes under the airbag, scan the instrument cluster..
light8008
Sep 21, 2011 04:02 AM
mrk3cobra
May 8, 2009 02:04 PM
uruk
Nov 16, 2007 07:36 AM
captcaos2002
Nov 6, 2006 08:16 PM
budnfrida
Jul 11, 2006 12:39 AM
