Codes
Old Feb 24, 2012 | 07:54 AM
chocalotstarfish's Avatar
Super Moderator
Default Codes
1.8t AWM
Codes from the new b5.5... p1116 p1103 p1531 p0012 p0130 p1479 p1602 p1517. With out driving it and just letting it idle for a few mins the two that came back p1531 p1116.
So the P1531 is the Camshaft Timing Adjustment: Open Circuit which seems like it would explain the loud knock I have. Ideas?
P1116 is Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1: Open Circuit which who knows. I'm mostly worried about the P1531... I have a video I will post in a few mins of the car running...
Old Feb 24, 2012 | 08:14 AM
M5S5's Avatar
Tech Certified
I i mistaken on the year of the car. I show the AWM engine in Audi vehicles starting in 2001 not 1999?
has the engine been swapped?
Old Feb 24, 2012 | 08:24 AM
M5S5's Avatar
Tech Certified
Looks like your front o/2 sensor heater is shot.
You will have to also check camshaft adjuster for power & activation.
Anyone with 5000+ posts on the Audi Forums & own a Audi should own a Vag-Com by now! Just my opinion.
They have bi-directional testing & factory codes #'s that can help with diagnostics. You can also see what is a hard code & a pending code.
Old Feb 24, 2012 | 08:36 AM
Super Moderator
Old Feb 24, 2012 | 08:43 AM
CCA4's Avatar
B5.5= VW, not Audi.
I'd start with replacing the pre-cat O2 sensor and the cam position sensor and see where that leaves you.
Old Feb 24, 2012 | 08:45 AM
M5S5's Avatar
Tech Certified
O.K. we are dealing with a race car? I am assuming by the the way the car accelerated on the video.
Old Feb 24, 2012 | 08:48 AM
M5S5's Avatar
Tech Certified
Originally Posted by CCA4
B5.5= VW, not Audi.
I agree with the o/2 sensor but the description for the other code is for camshaft adjuster , not a cam sensor! 2 different components.
If we had factory codes to go on it would help.
Old Feb 24, 2012 | 08:51 AM
Super Moderator
Well the Audi's I own are OBD-I so no vag com but I do own 6 scanners which is how I pulled the codes! It's harder when I can't drive the car to activate new codes and it just has to idle. I'm already looking at a cam valve it's only $120 but I was asking if there might be any other causes to trip that code. Thank you though.
Old Feb 24, 2012 | 08:56 AM
Super Moderator
B5.5= VW, not Audi.
The one under my name is my old A4 AEB
Correct me if I'm wrong but didn't the 01 b5.5 A4 have a AWM also? Which is why I cross posted it here. Same motor. doesn't matter if VW or Audi
Old Feb 24, 2012 | 09:01 AM
CCA4's Avatar
You're right Don, its exactly the same motor. I was just pointing out to that dude that the term "B5.5" refers to Passats. 01.5 A4's like mine also run the AWM 1.8t.
