Coil advice for a 2.8 v6 30 v
Old Dec 8, 2014 | 07:42 PM
normal's Avatar
Default Coil advice for a 2.8 v6 30 v
Hi - I've been dealing with a misfire issue and will definitely be replacing wires, plugs, and my breather hose assembly. Have a question about options re: coil. I believe that my existing coil is OK, but it is definitely old. I usually buy parts off amazon when I can and there are 3 options: ~ $50, ~ $70 and the $160 Bremi.
So my questions are:
- Do coils either work or not work, OR, does their performance degrade over time. (i.e. should i just replace it while i'm doing this other work anyway, even though existing coil may still function)
- If I do replace - would you recommend going with the Bremi or rolling dice on one of the cheapies:
$50
Amazon.com: 1998-2001 Audi A4 A6 Quattro 2.8L V6 Ignition Coil Pack # 078905104: Automotive Amazon.com: 1998-2001 Audi A4 A6 Quattro 2.8L V6 Ignition Coil Pack # 078905104: Automotive
$70
Amazon.com: Brand New Ignition Coil Pack AUDI & VW 2.8L V6 Complete Oem Fit C256: Automotive Amazon.com: Brand New Ignition Coil Pack AUDI & VW 2.8L V6 Complete Oem Fit C256: Automotive
Bremi $160
Amazon.com: Bremi Central Ignition Coil: Automotive Amazon.com: Bremi Central Ignition Coil: Automotive
Old Dec 9, 2014 | 01:27 AM
bmoore98A4's Avatar
those are cheap as hell. first do a resistance check between the mated coils and see if there is an irregularity. check plug wires/move between known good cylinder/known bad. if the coil is consistent, or if the misfire moves accordingly, you have your answer. ide keep the stock coil if you can. 50$ is just too good to be true.
Old Dec 9, 2014 | 08:17 AM
normal's Avatar
I've already tried swapping wires (removing two wires from both coil/plug and swapping them). The misfire did not follow with the wire (but think that confirms wires are ok, not necessarily the coil?)
Should I try re routing wires to test the coil? For example routing #1 wire to #2 cyl and vice versa. I was unsure whether messing with order would mess anything up and also noticed that it didn't seem that there was enough slack in wires to reroute
Can you describe in a more detail how/what you do with swapping (or rerouting) wires to test coil, please ?
Old Dec 10, 2014 | 07:44 PM
mtroxel's Avatar
Ryan,
Before you throw money at those coils, check your PM. I sent you the .pdf for checking them.
Old Dec 11, 2014 | 08:11 AM
normal's Avatar
Awesome, thank you for your (continued) help!
Old Dec 11, 2014 | 02:43 PM
elduderino200's Avatar
mtroxel can I get in on that pdf? I replaced my coil, wires, and plugs, and I'm still getting misfires.
Old Dec 11, 2014 | 02:44 PM
mtroxel's Avatar
Nov 20, 2010 03:40 PM
drft1
Jul 5, 2010 12:19 PM
chongboi
Nov 13, 2009 06:02 PM
kraylon
Jul 29, 2009 12:19 AM
AudiATX
Sep 9, 2008 10:12 AM
