coil packs
Old May 2, 2010 | 08:32 AM
audiquattroa4's Avatar
Member
Default coil packs
whats the best coil packs to get for my car? just a 98 1.8t quattro k04 turbo, giac chip. Its misfiring and idk if my packs have been replaced and i no its a common problem, so i thought i would start there. Thanks
Old May 2, 2010 | 08:37 AM
Member
its the aeb motor too.
Old May 2, 2010 | 08:53 AM
chocalotstarfish's Avatar
Super Moderator
Are you getting a CEL? If so do you have a VAG to show what cylinder is misfiring? Tkae the coil out of that cylinder and move it to another if the CEL moves then it's your coilpacks for sure.
Old May 2, 2010 | 08:39 PM
MartinCieslak1's Avatar
Some people had trouble with brand new jobber coil packs so if you get new ones either oem audis, bosch or beru something original..
Old May 2, 2010 | 09:36 PM
srlito's Avatar
make sure your plugs are gapped correctly for the tune also.
Old May 3, 2010 | 11:52 AM
Member
misfire in cylinder one and two, pulled a multiple misfire code, and whats the right gap size.
Old May 3, 2010 | 12:32 PM
dragonrage's Avatar
.028 for your car. That can indeed cause misfiring.
Old May 4, 2010 | 06:42 PM
Member
worked, dropped them to .028 and no misfing, another problem im having is i cant hold boost, it tapers off bad, not like normal boost taper, and i was reading on a forum that the intercooler lines could be clapsing caus im going from holding 15 pounds to tappering to 10 pounds with no boost leaks anywhere? thanks
Old May 5, 2010 | 10:26 AM
joenelson7687's Avatar
Upgrading your intercooler pipes can only help you. If you have a stock side mount, I have some hardpipe thats a stock replacement. Just PM me.
Old May 6, 2010 | 04:40 PM
Member
pm sent thank you
babern00
Oct 2, 2011 08:52 PM
drft1
Jul 5, 2010 12:19 PM
kraylon
Jul 29, 2009 12:19 AM
Apdl
Jul 8, 2008 06:25 PM
boy412
Jul 24, 2007 04:09 PM
