coilpack help needed
Old Jul 25, 2012 | 04:31 PM
trev123's Avatar
Default coilpack help needed
I fitted a fuel part coil pack and i now have 2 fault codes 17763 and 17769 help needed on how to fix i know what the codes are.
Old Jul 25, 2012 | 04:38 PM
DanaB6's Avatar
Those codes are for cylinder 1 and 3. Are the coils in all the way? Check your coils and connectors.
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Misfire
No Spark
Possible Causes
Faulty Ignition coil(s) with output stage
Fuse(s) faulty
Wiring and/or Connector(s) from coil(s) to ECM faulty
Possible Solutions
Check/Replace Coil(s)
Check Fuse(s)
Check Wiring and/or Connector(s)
Old Jul 26, 2012 | 03:29 PM
trev123's Avatar
thanks for reply . ive seen a technical bulletin for these codes. do you know if there is bulletin for audi a4 1999. apt engine .
Brochacho
Apr 25, 2012 08:12 PM
murdox
Sep 6, 2011 08:14 AM
pa4ul
Feb 16, 2008 11:49 PM
pa4ul
Feb 16, 2008 11:11 PM
EVOLA4
Nov 9, 2007 11:42 AM
