Coils, Wires, Plugs.. oh my..
Old Apr 26, 2011 | 03:52 PM
robertclark0's Avatar
Default Coils, Wires, Plugs.. oh my..
My 97 A4 1.8T Qauttro is starting to give problem.
Im getting codes for Cylinder 2 and 4 misfiring. I plan on replacing all the Spark plugs because its time for that any way.
However I'm thinking that it may be more than that base on what I've read and seen.
If I have to replace the ICU on the air box, I have read mixed reviews if I should, or have to replace the coils with it?.
Also anyone ever used the Bosch 7402 plugs? I just ask because they are way cheap.
This probably will turn into a more of an engine make-over.. so if I do the plugs, and the ICU, and if I have to do the Coils, then im just going to do the wires too.
Old Apr 26, 2011 | 03:57 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Try swapping the coils and see if the misfires follow the coil packs. It could just be the 2 packs going bad at the same time, and you should just replace all 4.
If the misfires don't move, or are random, its most likely the ICM. You wouldn't have to replace the coil packs but it can't hurt.
Old Apr 26, 2011 | 04:57 PM
krazzz's Avatar
The oldest 1.8 that I have had was a 99 but it had the coil packs that sit on the plus so there are no "plug wires." I think yours should be the same way.
Old Apr 26, 2011 | 09:51 PM
ImTheDevil's Avatar
^^^ correct, these cars are coil-on-plug ignition.
Old Apr 27, 2011 | 01:33 AM
A4 2000's Avatar
Trouble shooting with the least expensive route first will most likely save you some $$. Replacing the plugs is always a good starting point. Make sure they are gapped to spec. Something as simple as this can be often neglected, which then leads to problems. Then I'd say to look into checking the coil packs and lastly the ICM.
skidmarkart
B7 Models
Apr 10, 2015 01:46 PM
nick17
Jan 5, 2010 10:08 PM
SAudi
Apr 14, 2009 12:24 AM
99 audi
Mar 30, 2009 06:58 PM
TannisB
Jun 26, 2008 10:28 AM
