Cold Air
Old Aug 31, 2008 | 05:15 PM
czabelin's Avatar
Red face Cold Air
So i'm needing a cold air intake which i should have done while ago. which brands are good and where can i get it?
Old Aug 31, 2008 | 05:26 PM
ghost6303's Avatar
you only need it if you want to hear your turbo, theres no reason to get rid of your stock airbox performance wise unless your going above 4-500hp. just get a cone filter and a silicone intake hose and put your MAF between the two.
Old Aug 31, 2008 | 08:29 PM
TommyGunns's Avatar
I know some people on here say not to wast your time on them, but I really like the one that I got from EuroSport Tuning. It has a new tube for your MAS, and the intake tube pulls in air from just under your headlight. Yes you can hear your turbo, and it does make the exhaust note more aggressive. When you look at all it comes with, its a pretty good deal.
http://www.eurosporttuning.ca/Mercha...Code=A-A4B5-en
Old Sep 2, 2008 | 12:19 AM
czabelin's Avatar
i already have a cone air filter i just assumed cold air would make a big difference.
Old Sep 2, 2008 | 02:16 AM
Audi_Skydiver's Avatar
Are you turbo'd? If so you will LOOSE performance unless you build a heat shield to block the hot air from the turbo. If you don't you will be sucking in hot air that surrounds the turbo thus loosing power and wasting money.
Josh
Old Sep 2, 2008 | 05:58 AM
andry's Avatar
yes it would make a difference but no much. you need full exhaust if you want make a big difference
Old Sep 2, 2008 | 02:36 PM
A4speed's Avatar
dlcain
B7 Models
Jun 18, 2014 02:56 PM
jinxonator
Feb 25, 2010 02:46 PM
motojoeis01
Dec 20, 2009 11:22 AM
M3Armand
Oct 17, 2007 11:08 AM
