Cold Start Oil Circulation
Old Jun 21, 2012 | 12:24 PM
bmoore98A4's Avatar
Where is this valve??? I added seafoam and it cleared 90% of the chatter up. I'm really stoked about it lol
But this valve. Is it in the same assembly the oil coolers are part of? And after replacing all the gaskets, I still weep oil. Could this valve be giving me the 1 or 2 drips/night?
Old Jun 22, 2012 | 08:42 AM
aragorn's Avatar
The oil cooler and filter attach to an alloy housing, which is bolted to the block, and houses the oil pressure switch, turbo oil feed and oil temp sensor.
If you remove this housing from the block, in the back of it is a 1 way valve thats screwed in, that stops oil flowing back to the sump when the engines shut off. I've seen the valve work loose before, resulting in the oil draining back and a loud death rattle for a second or two on engine start.
whitneyj
Feb 28, 2014 11:37 AM
B5 Audi
Oct 20, 2010 06:28 PM
ainarssems
Feb 5, 2008 11:19 PM
chusaiyan
Jan 25, 2008 05:43 PM
silver_rings
Apr 8, 2005 11:33 PM
