Comprestion test results
I did a compression test on my audi over the week end and here are the numbers
cylinder #1 130psi
cylinder #2 120psi
cylinder #3 130psi
cylinder #4 120psi
cylinder #1 is closest to the front or the car and cylinder #4 is closest to the firewall. the compresion tester i used only reads in 10psi increments.
are these normal? they seem alittle low, but all are with in 10% of each other.
I wish i would of found the Diy on this sooner these numbers are on a cold engine, i did the test as a spur of the monemt thing since i found my compression tester i wanted to use it,but forgot some of the steps ill do it again and compare the numbers.
cylinder #1 130psi
cylinder #2 120psi
cylinder #3 130psi
cylinder #4 120psi
So these number thusly mean squat. A proper compression test is performed on a warm engine. Like Mike said.
we all make errors from time to time
No, just kidding. Post the numbers with a warm engine. I bet you'll be happier with the results.
well i did it on a warm engine this am and the resukts are:
cylinder #1 190psi
cylinder #2 190psi
cylinder #3 180psi
cylinder #4 190psi
but i also think my compression tester is a pos since i did each cylinder 3 times hitting the presure release on the compression test after each time, and i got 3 different numbers from any were from 180-240psi the numbers above is the lowest i got.
cylinder #1 190psi
cylinder #2 190psi
cylinder #3 180psi
cylinder #4 190psi
what does it mean if the numbers are low and you put a splash of oil in the cylider and it goes up on the compression?
